Air Intake Help!
2K views 4 replies 3 participants last post by  fourseventeen
New to the RZR community, but havd already heard that one of the first things to do is up grade the air intake. Any suggestions on a product with little to no modifications and without breaking the bank!
Thanks for all the help!!!
UMP is prolly the best to keep ALL types of sediment out of the motor, especially the silty real fine stuff. If you run in sand or heavier dirt the K&N system is the easiest to install and produces the most HP from my personal experience.
319 sounds pretty good. Need to remove the bed to get to the air chamber...once you have that out you need to drill a single hole in the chamber and you need modify the airbox hole to make it larger. Thats about the toughest part. For the average guy I would estimate about 2 hours labor to install.
