61 - 80 of 125 Posts
craigstumph
Discussion Starter #64
The most features in a CVT Temp Gauge available!
Need mounting advice. The manual shows different mounting than in these pictures. I have a 2019 Turbo S. Should I mount on top or on back?
Instruction Manual:
Forum Pic:
craigstumph
Discussion Starter #72
The manual has the best location for the most accurate belt temp. That position won't work on a Turbo S. The forum pic is correct. Take the cover off and have a look.
craigstumph
Discussion Starter #75
How is this gauge with water?
Ip67? Safe to use a pressure washer around it?
I do not spray any of my gauges with water directly. I usually just wipe them down with a towel that I throw over them before washing. There are several definitions of IP ratings. However this one seems to be the easiest to post without reading an entire novel:
  • IP65 Enclosure - IP rated as "dust tight" and protected against water projected from a nozzle.
  • IP66 Enclosure - IP rated as "dust tight" and protected against heavy seas or powerful jets of water.
  • IP 67 Enclosures - IP rated as "dust tight" and protected against immersion. for 30 minutes at depths 150mm - 1000mm
  • IP 68 Enclosures - IP rated as "dust tight" and protected against complete, continuous submersion in water.
Source:
