Is the aerocharger designed to work on the stock compression as shipped? What boost does this kit run at out of the box? I see there are springs to change the boost, does the kit come with a variety of springs? I don't see them forsale anywhere. If they are shipping this to be a bolt on and go kit with stock compression, what is the crank or rwhp as shipped?
Any issues with fuel supply? For example if you modify the engine and want to crank it up to 11 or 12psi. Is it as simple as changing the boost springs? Does this turbo handle the heat of that much boost ok without the additional cooling of the oil like other setups?
