I went riding last weekend. I got a check engine light while loading the night before (520344-17). I went any way hoping it might miraculously clear itself. It ran fine throughout the day but the code never cleared. The MX manual states it’s an “Adaptive Fuel Correction Bank 1 – Valid But Below Normal – P-CODE P1170.” That’s Greek to me. Based on what I’ve read on the internet, it’s most likely low fuel pressure (lean condition) caused by a bad fuel pump. Is there a quick and easy way to install a fuel PSI gauge without splicing (cutting) into the fuel lines?
Also, I broke two center caps while rock crawling. Are the OEM TRE center caps the only center caps that will fit the TRE beadlock wheels? The OEM replacements were ~$35 each. I could buy four aftermarket center caps for a standard XP 1000 non-beadlock wheel for ~$20. Granted, they don’t look the same. But, every website stated they don't fit my TRE. I'm just questioning is that because they won't fit or because they don't match?
