Ok, so I know on the front that it should hvae 1/8" ouon toe and the camber should be 0-1* postive since you gain negative camber when moving. Is this the same for the rear? Also, the rear only has the adjustment points at the pivot end of the lower control arm. It looks like that both will need to be adjusted to accomplish the camber setting. Then it looks like you will adjust the front or rear one to accomplish the toe, correct? However, that being said, wont it mess the camber up? Also, how are yall getting your camber measurement?
