1 - 20 of 80 Posts
Added OEM Polaris XP1K Trails & Rocks Edition high clearance lower A-Arms and Rear Radius Rods to my 2018 XPT
A-Arms:
1021482-458
1021483-458
Radius Parts:
Radius Rods 1543751-458 Need 2
Bracket Spacer 5262747-458
Bracket Spacer 5262748-458
Bolts 7520478 Need 4
Front A-Arms are a cheaper alternative to SATV and Highlifter. Adding the rear radius rods is actually more expensive, but bolts right on and no need to modify or clearance the trailing arm.
Josh
Very cool. Can you order them in different colors? Did you think about powder coating them to match before you installed them.
2017 XP1K T&R Edition the hardware is black
2018 XP1K T&R the hardware is a dark silver
2017 XP1K Highlifter the hardware is Blue
2018 XP1K Highlifter the hardware is black
I chose black as it's easier to upkeep, and makes a nice combo with the silver. I definitely did not want blue, way too much color IMO
Excellent info. This is something i was going to be doing.
$574.86 for the parts you listed from Partzilla.
I have the same machine and all the parts im buying are black as well. Not into making it a fashion show with matching colors. I got black tree kickers, black bumper, black seat belts, black mirrors, gonna have solid black seats, etc.
Discussion Starter #6
Yep, and those rear radius bars are Beefy. Are they worth the $172 each? I bet they are, solid bar and no hein joints is what I liked the most.
I ordered all those parts from Partzilla. Shipped super fast.
Any chance you could dig up the part #s for the A-Arm bushings? Seems like i'd rather buy those and put in the high clearance a-arms and leave the bushings in the OEM XPT a-arms.
Discussion Starter #8
BUSHING-STANDARD 5452233
You would need QTY 8 to swap just the lower A-Arms
I wanted to add, that this part is mislabeled on some XP Turbo parts diagrams and correctly labeled on the XP1000 diagrams.
This upgrade doesn't change the camber/toe/alignment at all? The high clearance arms/bars are the same length eye to eye as the OEM turbo arms/bars?
Good find and info, trying to get the silver off the 2018 model in high clearance arms and radius rods. How did you find the codes for high clearance and colors. I'm on Rocky mountain and see choices but can't chose specific model. Didn't see that option on partzilla either.
Sent from my SM-G950U using Tapatalk
Great info
Discussion Starter #12
I received part numbers from member Got4wd and also in my thread here:
http://www.rzrforums.net/general-rzr-discussion/486450-xp1k-trails-rocks-lower-arms-radias-arms.html
Trails & Rocks in Silver
WELD-CTRLARM,HC LWR,FR,LH,64,S [+]
1021482-385
WELD-CTRLARM,HC,LWR,FR,RH,64,S [+]
1021483-385
LINK-RADIUS ROD,BTM,HC,SLV [R99AL][R99B
1023240-385
You'll notice the silver parts are more expensive than the black parts.
Thanks. That looks to be the parts numbers I got. So the hc is high clearance in the code. And yep silvers more.
Discussion Starter #14
Nope, doesn’t change anything. All OEM parts that match. No need to set heim joints on radius bars or setting camber like SATV lower arms.
Bolt on and drive it like ya stole it
GREAT JOB MAN
I have a dynamix. So would need red. Could you send partnumbers for all red a arms, bushings, red radius rods etc?
GREAT JOB MAN
I'm with you...I hated asking for a part number for the bushings from the OP, but navigating the Polaris parts schematics seem to be a little more involved than looking for motorcycle parts. Guess I know what i'm looking for on motorcycles before i even start looking.
Props to the OP again for laying it out so well.
1 - 20 of 80 Posts
