900xp weaknesses?
28K views 19 replies 18 participants last post by  Ki4wau
Hey all, I just recently joined the RZR world and bought 2012 with 800 miles in it. My question is , what are the things that cause problems that I should check and make sure something serious doesnt break?
Thanks in advance , George
I feel the most common problem with the rzr xp 900 was the air filter. If it is not sealed properly dust can get by and into the engine.
Here is a link to the R2C filter for the XP900. We worked with R2C to make a thicker lip for a better seal around the air box. The R2C filter is made with synthetic material and is easily cleaned by blowing from the clean side out or vaccumm from the dirty side. Filters better than the paper filter.
R2C Panel filter XP900
We also offer our upper air box keepers to help better support the airbox to avoid the potential of ripped intake boots.
RZR XP900 (Upper Air Box Mount Keepers)
Let us know if there is anything we can do to help your RZR be more reliable.
Regards
The intake boots, wheel bearings, carrier bearing, tie rod ends are things to keep an eye on.
In fact, it wouldnt hurt to dis-assemble the machine up to the airboots between the throttle body and head annually for inspection. Mine failed and cost big bucks for a complete engine rebuild. all over a 29 dollar rubber part.
#16 · (Edited)
Some said the air cleaner issue happened when too much gear was stored on the bed. too much weight and somehow it would push on the air cleaner. The other issue I have had (and others too, I hear) is the hydraulic brake sensor, which detects the brake is being pushed during startup, tends to fail. The way u tell is u have to push the brake real hard in order to start the rzr.
Keep thinking about "upgrading", but too many people tell me they miss their xp900's. the 4 seater xp900, imo, was the best rock climber Polaris ever made.
xp900's drive like a nimble go cart, whereas the newer, bigger machines feel like driving yellow school buses!!! ha ha
