1 - 10 of 10 Posts
Installed my TricLED's on my 900xp I got from Ben today. Great product! Fit perfect. I pulled the headlights for the install. Make sure you know how you want them positioned on the headlight BEFORE you stick them on. Reason for this is the tight fit of the 900, 800 and 570 plastics. You want to make sure they clear your headlight openings before you stick them on. There is slight wiggle room on the 900/800/570 headlights to clear the plastics. Mine ended up perfectly centered on each headlight and still cleared the plastic opening. Give Ben a call and order some of these things up. They're cool! :eek:k:
Looks great Ken!! Yes, the 800 / 900 body work varies quite a bit from vehicle to vehicle.
We sized the rings at 97% of the external lens size to accommodate for the 20 different vehicles we tested.
P.S - You do NOT need to remove the headlights for installation, however, if your body work happens to be very tight, it may make the process a bit easier.
1 - 10 of 10 Posts
