900S when to use low range?
8.1K views 37 replies 27 participants last post by  FireWire
when to use low range vs high?, RPM/MPH
I use Low range when doing an average of less than 25 mph, which is most of the time, as I am a trial rider. The 900 has a more useable low range than some of the older rzr's. I have 4817 on my 900s and other than a failed stator and voltage rectifier, I've had no problems..
The 900 S can go in low gear up to 40-45. My belt was just changed at 2000 miles and it looks new. I am only in high gear on cement or fast fire roads. I am in low 95% of my ride. I also talked to the techs at Camp RZR and they totally agree with this type of riding in low gear. They said that is what it is meant for, that's why I love the S.
I guess I go against the popular consenus here. I only use low gear on steep hill climbs, deep mud and technical stuff. I'm in high gear most of the time. I'd rather keep my rpms down then having it tached out all day. I'm sure my belts won't last as long as guys running low most of the time but I'm betting my engine runs cooler. Just my preference.
X2 high gear 95% of the time 700 miles and some change,still factory belt (knock on wood)
I agree with superjunior and tater1. I rarely use low and don't do a ton of high speed riding. I get that it's a little harder on the belt but I hate the sound and feel of a machine ripping at high rpms and going slow. I guess I'll just have to replace my belt more often than most but at least my engine won't be worn out from all the revs.
I was one of those guys that would always drive in high and only going into low if climbing a long steep hill or towing someone or something. That was until I busted a belt when I was in too much of a hurry to get up a hill and didn't feel like stopping to change gears. I was almost at the top and the belt broke. For those who insist on always driving in high, you may want to carry a spare belt.
#23 ·
I'm almost always in high unless in a steep technical area. It's always worried me the sound it makes at high RPMs going slow. I might be paranoid, but a belt is cheaper than an engine. I dunno.
Sent from my SAMSUNG-SM-N910A using Tapatalk
#31 · (Edited)
The benefits are better maneuverability at slow speeds on hard pack, like your driveway , shop or while loading on to a trailer. My trailer has a floor covering and when I am locked it will tear up the carpet when I am unlocked it will not. You get a lot tighter turn radius when the rear diff is unlocked
Here is an example the first run is locked and you can hear the tires chirping
#29 ·
I find this very interesting. We're not talking a minor difference. If you consider the life of an engine in terms of total rpms over the life of the engine it's significant. I'd really like to see some hard facts if they exist.
