I have a 2011 RZR 800S and I need to change the 2nd/4wd switch to a 5 pin rocker switch. Has anyone done this and can you tell me which wire goes where?
I appreciate the answer! This helps a lot! Thanks!The gray wire is the wire that needs to be the "switched" wire, it is the negative that sends signal to the ecu that engages the front diff. I'm not sure how you will make everything else work in the switch. I used a 8 pin switch that I bought from Team FAS Motorsports here on the forum when I replaced my awd switch.
I know this is an old post and I was wondering if you did figure it out which by now you probably did but there is a way to do it. It requires a relay and it is very simple. The only thing is both the top and the bottom lights will light up at the same time when you turn on your ignition.I have a 2011 RZR 800S and I need to change the 2nd/4wd switch to a 5 pin rocker switch. Has anyone done this and can you tell me which wire goes where?
