Ok, I've been searching tons and have seen lots of info, but so far can't figure it out yet. This isn't my RZR, it's my buddies, an 08.
The switch lights up, but the 4x4 symbol on the speedo does not. The gear selector shows, L,H,and R. At the front diff, there is a BRN/WHT wire, and a Grey wire. With a tester, and the switch on, there is 12v at the Brown wire, and the Grey shows like an alternating ground? Like a flasher, ground, not, ground, not, etc. Reading posts, it looks like the brown was supposed to be ground? But with the switch on it that brown has 12v.
What could cause the 4x4 to not know that is in gear when the gear selection lights up and works on the speedo?
Any thoughts? It was working properly, then he went to use it and it didn't work. No water crossings, etc, just didn't work. Because of the lack of 4x4 symbol, we are thinking it has to be electrical something.
:question:
:question:
