Need help with the 4 wheel drive. Drove my 2015 xp4 1000 Saturday and everything worked great. Installed my Super ATV Rev 1 tune this morning and then went on a 25 mile ride in the desert. Noticed the back end drifting more than usual. Normally on loose dirt/ gravel I run it in 4 wheel to not slide in the corners as much. I run it in 4 wheel on either low or high and sometimes high speeds. Anyway the 4 wheel drive was not on even though the light on the switch is on. My first thought was it was the tune. I reflashed the ECU several times when I finished the ride. Still no 4 wheel drive. I'm puzzled and think this is just a timing coincidence. But I need to rule it out so Super ATV is calling me back in the morning with there tune specialist.
Could be a seperate failure, most likely is. Wiring problem, front diff? Has anyone on this forum had this issue and what was the failure/fix? I need help please! Thanks
Sent from my SM-N950U using Tapatalk
