30" LED Light Bar Noise
27K views 25 replies 16 participants last post by  Boburk
I have a 30" Totron light bar. When I turn it on there is a whining noise. The 2" dually lights I have do not make this sound when they are on.
Does anyone else have this issue?
I know a lot of people have a 30" light bar. Does your's have a high pitched humming noise when it is turned on, or is it completely silent? It is not loud but you can hear it.
I dont want to start going through my wiring if all the bars have this noise when turned on.
i have a couple different light bars. My Rigid doesnt do this but BBM and another ebay knock off have the hum. I might try grounding to the fram also but I called the dealer back for the BBM and they didnt seem too concerned, i ran it for about 8 hrs now and no problems and you dont hear it when the machine is on anyways
I tried a few different ground locations. All had the hummmmm except one ground that wasn't great. There was no hum but the lights were not as bright as the ground block or other locations.
I agree that you can't hear it when the machine is on, I just wanted to make sure the noise wasn't a issue that could effect the light bar.
#21 ·
Also another weird thing Ive been thinking about my 30inch light should pull like 13.8 amps I have a 10amp fuse in my block and it has never blown, even after over an hour of strait on. Does that mean my light is derating and not pulling full current maybe causing the hum?
#26 ·
I am surprised you get away with a 10 amp fuse, but lower does make some sense. Most people divide the wattage they pull by 12 to get amps. So a 180 watt bar, they figure is 15 amps. Well....not running your battery should be about 12.5 volts, and running it should be about 14-14.5 volts. So if you divide the 180 watts by 14.5 you get 12.4 amps. So a 15 amp fuse should be plenty...10, not so much.
Sean
