1 - 2 of 2 Posts
I am driving myself CRAZY trying to make this decision.... I know the 27 zillas would be the most sensible choice, but the 27 zillas are really only 26" which is only 1 inch above my stock tires. I really want the 28" Zillas(27 actual ) but I dont want to have a bunch of problems with my new 2012 RZR 800 LE. I will be buying the 2" Racer Tech lift kit. Will the 28" Zillas, with the racer tech lift cause more issues ? Is the lift kit alone all I need to comfortably run those 28's ?
Should clear with the lift but you will more than likely need spacers on the rear to clear the motor mount with stock rims.
1 - 2 of 2 Posts
