1 - 20 of 32 Posts
2020 900 Trail Fox Edition
I changed the oil for the first time awhile back and kept the oil change reminder at 25 Hr. Is this a good time line or should I increase it to 50. I don't do balls to the wall type of riding and have never hit the rev limiter. Mostly slow under 5K rpm. Wonder what the more experienced RZR drivers do?
2022 RZR Pro XP Premium
I did my first oil change at 20 hrs on my 2022.5 Pro XP and reset the timer to 20 hrs. Then if I am out riding, and hit 20 hrs, I really don't need to worry about it as I know there is a bit of a buffer. I figure oil and filters are way cheaper than engines and turbos. I don't really run that hard either, but this is the first new machine I ever bought, so I want it to last and I think the best way is to have impeccable maintenance completed on it.
The Lone Rzr
I don't have my maintenance schedule in front of me but I know my 1st oil change was at 8 hours, forget how many miles.
I look at miles and not hours. Miles can add up faster more than hours depending on your riding.
I do at least 1 oil change a year and 2 if I'm adding up some miles
I do 50 hours on the engine. Change everything else along with the engine every other time or 100 hours. That's usually at least 4 engine changes and 2 drivetrain changes per year for me. I grease at least every engine change and more often if I've been in a lot of water/mud. Fresh oil and grease are cheap insurance. I drain each fluid into a separate clean pan so I can inspect it under bright light for any signs of excessive wear. This allows me to catch any potential problem BEFORE it becomes a real problem.
Don't forget air filter... I think the air filter is every bit as important as the fluids. I follow the guidelines minus the front diff. as I rarely use 4 wheel drive... On the new one I purchased the extended warranty which I believe includes service but I need to check that. If its included then I'll just follow the guidelines and let the dealer do the work lol.
Checked- regular maintenance is on me...
Good, first hand information posted.
For me; service clock is set to 50 hours for oil/filter change. I check oil level before every ride. The oil color and smell are indicators if it need to be changing it sooner.
Trans: somewhere around the 100-150 hr mark.
Front diff: LOL, well it starts to leak out of the seal if it sits longer than week. It get's changed pretty often since there is a small amount of oil in the case. If there was not a leak, I still would change it very often.
Newer machine, I would change everything more often as the gears and parts finally break in and mate to each other. After that, go with the numbers you are comfy with.
For me I have went with this on RZR & Ranger....
Break in 25 hours all fluids.
Next 25 all fluids again.
Now I change them all at 50 hour intervals. 100, 150, 200, 250 etc. Maybe an overkill on dif and trans, but these things are high compared to fluid cost. I also enjoy wrenching on them.
I change oil and filter in the spring and fall. No idea the hours or miles. It’s overkill but I buy the filters in bulk and oil is cheap. I change the rest of the fluids with the fall service.
1 - 20 of 32 Posts
