2020 speedo not working code 2 84 1 and 2 84 2 check engine light on and steering light on
15K views 14 replies 4 participants last post by  Pinball Wizard
2020 speedo not working code 2 84 1 and 2 84 2 check engine light on and steering light on, I replace both sensors the speed sensor and brake switch and have driven it in low gear too, nothing has change still has no speedometer and check engine and steering light still, can anyone help me out please, Mark G
[/This Codes. 2-84-1. 2-84-2. place stop replace sensor's, please check your wire for power and ground and signal voltage at the transmission speed sensor, orange wire 12v black wire ground and green wire 4.95 volts. the codes indicates low voltage or open circuit. there and tool to find open circuit or to trace bad spot in your wiring harness and it only $20 and it very simple to use, not rocket science, found my problem it 10 minutes. Mark G
[/This Codes. 2-84-1. 2-84-2. place stop replace sensor's, please check your wire for power and ground and signal voltage at the transmission speed sensor, orange wire 12v black wire ground and green wire 4.95 volts. the codes indicates low voltage or open circuit. call me there and tool to find open circuit or to trace bad spot in your wiring harness and it only $20 and it very simple to use, not rocket science, found my problem it 10 minutes
I’m getting ready for work soon can’t talk now. Email me @ markguerrero@cox.net. There forums don’t like us leaving are phone numbers or email. So write it and I’ll send to my phone now. I will delete my email in 48 hours. I’m In Arizona mountain time. I work graveyard shift 10pm to 6:30am. I’m up a little bit in more till 9pm. Remember I have to delete my email in 48 hours
