21 - 28 of 28 Posts
Ok fellas... where do we start?
I'm sure we'll cover the basics...portals, arms, lifts, hard parts, and all the usual suspects. Where do we go from there.
What do you guys want?
How about a quick video on installing lower doors panels on my 2020 XP Pro Ultimate. Kind of a bummer they didn't come with them as look's like to new XP pro 4 seater has them from the factory. Yes having to spend another $200 on lower panels which it needs by the way sucks. I don't even want to share how much $$$ I have in this thing. I will share that it is everything the hype has lead it to be. Suspension is incredible, tons of power. Do not regret buying it. Sold my 2018 XP 4 seater with ride command to get it.
Hubert Rowland posted a video on you tube of installing the lower door panels on the pro xp, but I would imagine you got em on by now lol!
Contact: 855-743-3427
Discussion Starter #24
How about a gusset kit or something to strengthen up the area surrounding the radiators so they dont get crushed in a gentle rollover?
That's a pretty great idea. I saw some pics on here of a "gentle" rollover that did a TON of damage. Looks like that's going to be a pretty pretty weak spot.
We DO have a frame stiffener/gusset kit ready! https://www.superatv.com/polaris-rzr-pro-xp-frame-stiffener-gusset-kit
No coverage for the upper part, but its good to go ahead and get this on there early to prevent any possible frame issues.
Discussion Starter #25
Pro XP Winch Mount
Polaris RZR PRO XP Winch Mounting Plate
FITMENT
  • Polaris RZR PRO XP : 2020+
  • Polaris RZR PRO XP 4 : 2020+
FEATURES
  • Made with 3/16” heavy-duty steel plating
  • Laser cut and CNC brake press bent steel construction
  • UV-resistant wrinkle black powder coating prevents corrosion
  • Designed to work with Black Ops Winches
  • Installs quickly and easily
  • Compatible with many OEM and aftermarket winches
Mounting Holes:
  • 76mm x 169mm (3" x 6 5/8")
  • 76mm x 124mm (3" x 4 7/8")
Fairlead Bolt Pattern:
  • 109mm (4.29")
  • 152mm (5.98")
Works great with...
Black Ops Winches:
3500 Lb. Black Ops UTV/ATV Synthetic Rope Winch
4500 Lb. Black Ops UTV/ATV Synthetic Rope Winch
5000 Lb. Black Ops UTV/ATV Synthetic Rope Winch
Discussion Starter #26
Pro XP Tie Rod Kit
Polaris RZR PRO XP Heavy-Duty Tie Rods
FITMENT
Replaces OEM Part #:
1824946
FEATURES
  • 20% larger diameter tie rods
  • Hardened steel monoball tie rod ends
  • Stock length replacement
  • Complete tie rod assembly
  • Simple design for a quick, no-hassle install
  • Adjustable on the fly
  • Tie rods backed by a lifetime warranty
Tie Rod End Features:
  • Made of 4130 chromoly steel
  • Heavy-duty design
  • Precision blend of materials and heat treatment
  • M14x1.5 threads
21 - 28 of 28 Posts
