81 - 100 of 256 Posts
researching a rzr xp 1k 4
Did the Polaris Camp having anything to say about the RECall??
Sounds like it was ignored and you guys were able to just keep riding?
Not much they can say. They ddint have a game plan on what to do at that time either. Lol.
Sent from my SM-G930T using Tapatalk
I just recieved my 2021 Pro xp4. Initially they said it was expected to be affected. I picked it up Monday and they said it wasn’t. Also noticed they changed the shitty soft intake tube to a hard plastic tube now as well
Will this work with the AA set up and secondary?
Yes it works with the stock secondary with or without the AA kit. I do have the AA on the secondary already so this should make for a nice combo. I'll keep ya'll posted.
Just to be clear - the stm primary clutch completely replaces the whole stock primary clutch.
Here is some more info about what I believe to be the issue with the stock primary. A buddy of mine had a very similar issue on his 2018 turbo s where the central bearing came loose and worked it's way out. He got lucky and caught it right before it dismounted. See pics attached and zoom in on the center bearing. Polars replaced it for free last year.
when did you order yours? I ordered mine the first weekend of September. Dealer said that it’s built but still at the factory waiting to be shipped
Instead of waiting, I'm just replacing mine with a STM Rage 3 Primary Clutch. I've added bigger wheels and a custom cage so the clutch was going to need to be changed just didn't plan on doing it 3 weeks after purchase lol
Do you have the part number of the stm you ordered ? I noticed there are a bunch of configurations
Any chance you ran your VIN this morning? Yesterday mine was no affected and today it is. They are adding VINs to the list slowly.
For all we know, the recall may only require the units to be brought in for inspection. Maybe Polaris knows where the issue stems from, and if your clutch doesn't have it, there will be no need for parts and out the door you go. Kinda like the missing stitches from IMMI "click 6" harnesses.
I sure hope your right. My turbo s is sitting on the dealerships floor. I know they want my money ASAP
We would love to see some pics of the new intake if you don't mind? I would be interested to know how much a new OEM one would cost compared to aftermarket tubes.
Just got word that my dealer got an update today from Polaris on the recall. The process begins with an inspection and if needed a replacement. To perform the inspection, special tooling is needed. Tooling will ship to dealers next week.
Just received word from my dealership saying basically the same thing as timoloco. Mine is still at the factory though. I was told it could be shipped out next week with the issue resolved.
I just heard from my dealer and was told the same thing as well. They told me it was a balancing issue that requires the special tool.
Depending on changes you've made to your machine it will require different springs and weights, just call the number on the site and a specialist will tell you which parts you need and have it preconfigured to you for install.
Here's what mine has
STM Rage 3WCP Polaris Pro XP, XP-Turbo, Turbo S and RS-1 Primary Clutch
Choose a Spring:pATV22 Bright Yellow Primary Spring (2 1/2" load 29 lbs - 2 1/4" load 75 lbs - 1 1/4" load 260 lbs)Choose Base Weight:60 Gram Base HB Series Part# 1001584Desired Cam Arm Weight Set Up or Machine Modifications, Specific tire used and Elevation.:14-6-0 / .125 spring shim installed
