1 - 5 of 5 Posts
Link: https://www.utvinc.com/utv-inc-2019-polaris-rzr-xp-4-assault-roll-cage-package/
The UTV INC Polaris RZR XP 4 Assault Roll Cage is designed to fit the 2019 and newer Polaris RZR XP 4 SXS models, including XP 1000, XP Turbo, and XP Turbo S. This cage is 6" lower for the front occupants, and 8" lower for the rear occupants.
This roll cage is constructed of 1.75" 0.095 DOM steel and is fully TIG welded. Roll bar comes standard with an aluminum roof which features a rolled front sun visor and drip edge for protection from the elements. The roof is affixed to the roll cage using 1/4 turn dzus fasteners.
Cage can be customized for your wants and needs below by choosing options from the listed drop-down menus. Cage is compatible with the UTV INC Rear Pop Up Spare Tire Mount available here.
Cages are typically built to order and take 1.5 to 3 weeks from date of order to be completed.
! WARNING ! : UTVs, SxS's, ROV's can be hazardous to operate! Off-roading can result in serious injury or death. For your safety, please ensure you and your passenger(s) have adequate headroom before operating. ALWAYS wear proper safety gear! This cage cannot prevent all injuries. The aluminum roof is designed for sun shade only, and will not stop objects from protruding into the occupant area. You should only operate your vehicle after taking an off-road safety course. Keep all parts of your body inside the vehicle.
$1,850.00 + up
Discussion Starter #2
Need a new cage for your 2019+ RZR XP4 1000 or XP4 Turbo? Check out our new Assault roll cage specifically designed for the new 2019 Polaris chassis. Our Assault cage features 1.75" x 0.95" DOM steel, fully TIG welded, aluminum roof with DZUS fasteners, welded rear view mirror bung and single HD whip tab standard. Click on the link below for all the custom options available or give us a call at 480-718-5511.
LINK: https://www.utvinc.com/utv-inc-2019-polaris-rzr-xp-4-assault-roll-cage-package/
Discussion Starter #5 (Edited)
1 - 5 of 5 Posts
