1 - 20 of 142 Posts
craigstumph
2019+ RZR 7101A RYCO MOTO Turn Signal/Horn Kit
Application:
POLARIS RZR XP 1000 / 4 1000, 2019,
POLARIS RZR XP TURBO / 4 TURBO, 2019,
POLARIS RZR XP TURBO S / 4 TURBO S, 2018-2019
Kit Features:
Steering column mounted combination turn signal and horn switch, with four-way flasher activator
Front turn signal accent "fang" LED lights
Ties into the vehicle taillights as rear turn signals for a clean, factory appearance
Brake lights strobe in the first second when activated, and then stay on solid*
Uses the turn signal indicator on the instrument cluster**
*This feature can be disabled, per your preference.
**Polaris did NOT include factory turn signal indicators on machines older than 2011, as well as some models with the RIDE COMMAND DISPLAY, and some TURBO models. On other models, such as the 2019 RZR TURBO S, the vehicle indicators may not be compatible with the turn signals. This kit also includes dash mounted indicator lights to use as needed or per preference.
Ryco street legal kits have a turn signal with an integrated horn button and emergency flashers..The factory rear tail lights are used for the left and right turn signals. Illuminated license plate holder with night time running lights are integrated into the system to meet state regulations for highway vehicles. Wiring harness and detailed instructions are included with each kit. Satisfaction guaranteed.
Kit Includes:
Dash mounted indicator lights
105dB horn
Electronic flasher relay
License plate mounting hardware and LED plate light
Complete wire harnesses with factory-type connectors installed
All necessary hardware, cable ties, and connectors
Illustrated installation instructions
PM or Order online
https://www.proutvparts.com/collections/xp-turbo-s/products/ryco-street-legal-kit-for-polaris-rzr-turbo-s-turbo-1000-2019
My 2019 XP TURBO have the turn signal arrows on the cluster. Do you know if your turn signal light will be compatible with it?
craigstumph
Not sure yet, this is what Ryco says:
"On other models, such as the 2019 RZR TURBO S, the vehicle indicators may not be compatible with the turn signals. This kit also includes dash mounted indicator lights to use as needed or per preference."
Does this use the factory fang lights or does it come with new fang lights?
Just installed the RYCO MOTO Turn Signal Horn Kit on my 2019 Turbo XP 4, easy install, great product, only problem was that the indicators on the new style dash will not work, instructions and kit have the wiring for the pin out but it will not work, but it does come with LEDS to mount in dash and they are great. I had a 2017 General 4 with the same type of dash and worked on the indicators and the only way I was to able to get them to work was to add a voltage reg before the dash and only supply 12v, any more than that and the indicators would not work, only problem with that was that the voltage indicator on the dash always read 12v and not actual voltage. RYCO was very clear when ordering that the stock indicators may or may not work.
Don't get frustrated if the indicators on the dash do not work......Polaris issue not Ryco.
****UPDATE:*****
Was able to get the indicators to work on the dash, on the connector going up to the dash, (the one supplied by Ryco,) I pulled the blue heat shrink off, there are resistors on both wires, remove them and all is good. verified on 2 - 2019 1000 XP 4 Turbos.
1 - 20 of 142 Posts
