1 - 2 of 2 Posts
DMS Desert Rat
Tried reading through all the posts but could not find the info on the conversion, do you not use the old radiator shroud? Or do you get an S model version? This for a fang conversion front. Also, with no shroud where does the GPS go?
Wheel Bicycle tire Grille Tire Automotive lighting
Wheel Tire Vehicle Automotive tire Automotive lighting
Tire Wheel Grille Hood Automotive tire
About to start this myself on my 18 XPT. Just waiting on the dash support (doing front end and dash). I was told that you can recycle the old shroud but I ordered new one and the indicated front bumper brackets according to the 2019 parts diagram. There are a couple different versions. The 2019+ XP1000 and 2019+ XP Turbo have different shrouds. My XPT has the voltage regulator mounted up top so I will have to cut a section of the new shroud out for clearance. The 2019+ diagrams lists the shrouds with the radiator assemblies. Not sure on the GPS puck but I believe on the 2019+ style dash, they are mounted in the large void in the dash cowl.
1 - 2 of 2 Posts
