2018 rzr turbo primary clutch removal
14K views 7 replies 6 participants last post by  Hunterworks
Bought a new turbo a few weeks back and started to add a few things. I was trying to take the primary clutch off today but couldn’t seem the get the bolt to pop loose and didn’t want to snap it off! Anyone else run into this? Do I need to just get more leverage and crank on it? Any help would be great.
I just saw a post on a Facebook group about this. Below is a copy paste from the post:
Everyone including myself has a hard time removing the primary the first time. Put a lite coating of moly lube (assembly lube) on the puller threads and use a 3-foot cheater bar. Tighten the puller as tight as you dare. Lightly tap the puller with BFH, apply more torque, repeat several times and the primary will eventually pop off. Don’t smack the puller real hard since you can damage the crankshaft bearings or even bend the crankshaft.
