1 - 3 of 3 Posts
There's nothing wrong with the diff's YET, just trying to stay ahead and do preventative maintenance during down time.
I had ran several searches and read several posts on the forum and used Dr Google.
RockyMountain lists after market overhaul kits (front only), but read they leave out a few key items.
Does anyone have a list compiled for front and rear diff parts needed and or while im in there you need to replace XX??
or maybe an aftermarket vendor is better that the other for diff parts supply.
Thank you in advance
Front Diff:
Hub and Pinion Bearings
Seals
Ring Gear Roll Pin
Armature Plate
Sprauge Cage
Spring Retainer
Might as well put a new set of rollers in to while you're at it:
Take a look at the gear set and look for any chipping or cracking, but those are usually fine. Also verify the wires to the coil are in good shape and not pulling out of the diff case
As far as the rear goes....bearings and seals, and verify condition of all the gears and shift cogs, that pesky reverse chain is in there too...worth upgrading if you have the whole thing apart and have the funds available
Thank you VERY much RWB for the list and time
  • Like
Reactions: RWB713
1 - 3 of 3 Posts
