1 - 6 of 6 Posts
Can anyone tell me if I can run the rear (wider) wheels on the front - then I’d be running all the same 4 tires and rims around ....
Advise if there’s clearance or other issue. Thx.
No the fronts will rub.
Can anyone help me?? What interferes when running the 11” rear wheels and tires on the front??!!!!
please advise specifics ....
The wheel will rub on the tie rod & upper control arm. You can get around it with a wheel spacer if you really want to, but it messes with your steering geometry a bit
1 - 6 of 6 Posts
