1 - 3 of 3 Posts
I've got a 2016 RZR 1000S and it has become a pain to start. I can swap the injector wires and it will eventually start and idle. After it warms up I can swap the wires back to normal and it runs fine. What could be causing this? Any help would be appreciated. And unfortunately, no good shops less than an hour drive.
Well, looks like it is probably the fuel pump. Only have 52 psi at the fuel rail. Not a far cry from 58 but apparently enough to screw things up. New pump ordered. Will update!
1 - 3 of 3 Posts
