1 - 20 of 22 Posts
· Registered
Very cool, we are all very interested to see what kind of performance the aftermarket can bring out of this new machine. And congrats on becoming a vendor!
· Registered
hi SLP
i have a question for you
with the new hi altitude clutch kit for the 2015 900 s
i want to confirm can a ebs kit be added to it?
if you do will that effect in anyway the overall perfomance of the new clutching ?
thanks
hi SLP
thanks
Yes, EBS can be added to the high elevation SLP clutch kit on the 2015 900 S. It will of course help with steep downhill descents and it also makes the clutching a little more responsive in situations that require a lot of changes in throttle input and speed. The clutch kit also will help maintain a more consistent peak RPM for better performance in high-load situations. The clutch kit does not change the ECU limited top-speed of 72 mph on the S.
· Premium Member
Price w/EBS?? I am in Colorado in the mountains, Want a Guinea Pig??
Discussion Starter · #7 ·
The Clutch Kit itself runs 576.90 plus shipping. It includes the drive spring and TEAM Rooster weights. It also includes a new TEAM Tied driven clutch with helix and spring. The EBS system is an additional 93.72. Here is a link to the EBS page for the 2015 900 S on our website:
EBS Upgrade
As far as guinea pigs go, thanks for the offer, but I think we're good.
Discussion Starter · #8 ·
In our 2015 catalog, another new product you will find for the 2015 900 RZR is 1 3/4" wheel spacers. They are perfect for adding just a little extra width without making any permanent changes. Increased stability and easy on and off in case you still need to run 50" trails too, check them out! -
1 3/4" Wheel Spacers for 2015 900 RZR
Discussion Starter · #9 ·
Another new item for the 2015 900 RZR Trail/S/XC is our Aluminum Hawse Fairlead. It is machined from solid billet aluminum and is designed to be used with synthetic winchlines. Kit Includes: Fairlead, plastic winch cover, instruction sheet and necessary hardware.
Here is a link to our webpage for this product:
Discussion Starter · #15 ·
No more waiting! We have finished the development of our Super Silent Muffler for the 900 Pro-Star RZR.
With an exhaust tone that is 3 dB quieter than stock at cruising speeds, this muffler provides a much more relaxing experience when using your Trail, S, XC, or 4-seater 900. Idle sound levels are also lower with a 2 dB reduction compared to stock!
This muffler has superior fit and finish, with fully welded construction for excellent durability. It also comes with black ceramic coating (and an aluminum heat shield) to minimize radiant heat and give it a great look. It includes a spark arrestor and has also been flow tested and field verified to ensure optimum performance with a quieter exhaust note.
No fuel changes are required!
For more information, check out this link to our website:
2015-16 900 RZR Super Silent Slip-On Muffler
· Registered
Any performance gained or lost across the board with the quiet version exhaust SLP?
Discussion Starter · #17 · (Edited)
Exhaust flow and performance on the Super Silent Muffler are virtually the same as stock. There is definitely no loss in performance, but the gain is not large enough to notice. If you are looking for performance increases on the 900 with relatively low sound levels, I would suggest our performance slip-on:
Performance Slip on Muffler for 2015-16 900 RZR
Discussion Starter · #18 ·
We are now shipping these mufflers. The price is set at 449.95 plus shipping.
Discussion Starter · #20 ·
Hey Guys here's another item that goes right along with the quiet muffler:
Super Silent Intake
It runs 199.95 and utilizes a powder coated intake tube with pre-filter cover.
It's quiet, runs way cleaner air to the paper filter and gives you better performance.
1 - 20 of 22 Posts
