1 - 3 of 3 Posts
Hi, i could use a little help. the threads inside my crank shaft for primary are messed up, was rusty or corroded from sitting with out a bolt in it. i need some help on thread taps sizes. im not sure on the bolt size or thread. my bolt is a little messed up as well. bolt will probably thread in but after that its not gunna look pretty. thanks
FN
Part #Description
Quan
7​
7519287BOLT, CLUTCH (7/16-20 X 8.0 HEX BLK)
1​
Thanks, ended up re taping the threads and got it back together
1 - 3 of 3 Posts
