1 - 2 of 2 Posts
My razor is driving me nuts, I was getting several codes one pointing at the electronic gas pedal. Ended up finding water and mud inside the casing. So I replaced the complete pedal. At the same time I was getting codes from the throttle body. Check psi from fuel pump and I was right on what they required. I was contemplating the map sensor on the side of the throttlebody, as well as replacing the injectors. I took pictures yesterday from every direction trying to get all the information I could to make sure I ordered the correct parts when I discovered the plug on the opposite end looks brittle and discolored like it got hot. Can this end of the body be rebuilt or where could I get another body without getting rapped.
Show a picture of the brittle plug and I'm sure someone on here can help you find it. if it's a electrical plug you should be able to pop the wires out and put them in a new plastic. Just looking at a OEM parts schematic you might be able to order what you need.
1 - 2 of 2 Posts
