I want to disclose that when I ordered this lift, they told me they were not sure if it would work on the 2013 XP4. However; I felt if it did not work I would be able to put it on my 2012. So I ordered it. I started putting it on my 4-seater tonight, and apparently the mounting locations on the Walker-Evans shocks on my 2013 are wider. I would imagine the shocks on the 2-seaters and 4-seaters are the same, so has anyone put this lift on a 2013 2-seater because if it won't work on mine, I don't see why would work on that either.
On the rear there is a spacer on each side that is supposed to go between the shock and the bracket. The inside diameter is the same but on the outside diameter-one of them is noticeably larger, what is the deal with this?
Thanks, appreciate any help.
Brian.
Brian.
