2012 xp900 starter is binding up/hard to start. one way starter gear?
8K views 8 replies 4 participants last post by  Liquid 900xp
Have a 2012 xp900 that is becoming hard to start...when you hit the key it will just hang up(bind up) One person tells me its the one way starter gear another tells me its a design flaW polaris had on the intermidate shaft, that holds all the gears. How can I check and is their anyway to fix this design flaw?
#2 · (Edited)
There is an idler gear that is between the starter drive and the one way bearing . The shaft which is threaded into the engine case has been known to back out.
If it binds when you start the engine it is possible that it will break your engine cases.
The only way to check it is by removing the stator cover then remove the flywheel. No way to correct the design flaw, just put thread locker on the threads and torque to proper specs.
http://www.rzrforums.net/rzr-900-engine/129149-big-starter-problem-rzr-900-xp.html
