Rzr ran great no issuse, brought it home after a good ride, cleaned it up and put it in the garage. ran fine after cleaning, drove it in there. A couple of weeks later went to start it and would not crank.
Symptom other then it wont crank. I get -- where you would normally see what gear your in. when you turn the key to start while foot is on the brake nothing happens, no fuel pump no click of the relays, nothing. however if you where not to touch the brake and turn the key to start you'll hear a hum thinking this is the fuel pump and the gear indicator will then show up in what gear it's in, but the gear indicator will go back to -- with in 10 seconds, if you go thru the steps to get the gear indicator light up and change gear it doesn't change on the display unless I go thru and turn the key to start it then it will then light up the new position. with it changing gears I wouldn't think it's the gear selector switch.
here is another symptom - if you turn the key to start it and hear the hum and while it's in the "start" position if you were to press the break, the hum goes away and you hear the fuel pump relay click, let go of the break and you'll hear a click and the fuel pump starts running again.
what I have checked.
all fuses under the dash and the two behind the driver seat, ingnition switch connections, relays, pressure switch for the brakes, brake light comes on, however since the fuel pump goes off I did a resistance check on the presure switch and both wires are around 1 ohm basically a short... but what's odd is the break lights come on... not sure how to take that, thinking it's just completing the crkt.
I didn't wash it any more or less then I normally do and don't think it has anything to do with the problem but I've check all the wiring that I can see and nothing seems loose or disconnected.
I did remove the skid plate to clean it this time and did not put it back on yet, but I wouldn't think that would have anything to do with it.
any help would be great. thank you
