2012 570 Engine noise
8.6K views 8 replies 6 participants last post by  HONDARACER
Having some noise coming from the engine, first thought it was the cam chain tensioner. i replaced it and the old one i pulled out primmed rite back up. New tensioner did not fix the problem. Has anyone had to deal with this issue?
Welcome to the forum.
I have not and I don't recall seeing any other threads complaining of a noise that sounds like a loose cam chain. Hang in there though, someone may be along shortly that can help you.
Just got mine back from being in the shop for 3 months. The lower connecting rod bearing went bad. Had to replace the whole crank (rod is factory pressed on with bearing), cylinder, piston & rings. Fortunately I bought the extended warranty which covered most of it.
Hopefully this is not the issue your having, but it started out as a subtle knocking noise that ultimately became catastrophic.
Why does it take so long to fix a motor??! 3 months? Did you complain about the time? What did they say?
Dealer was real backed up, and extended warranty company made them jump through all sorts of hoops. Like all insurance companies they are great at taking your money quickly, but when the time come to pay out they will put up all sort of road blocks to try to not pay.
