1 - 2 of 2 Posts
Hello, I appreciate the info on the general discussion forums regarding input on the LE and S model since I am planning a purchase. I am a bit confused with looking at some threads on the 2011 being a little slower top end than the 2010 models. Just what is the stock speeds you guys are hitting with the 10 versus the 11?? What about after you remove the plastic bushing taken from the clutch what is your MPH? Finally what if you do some clutch work? Modded Clutch threads say 65 to 68 ? thanks
the 2008 is the only model with a limiter/spacer in the clutch.
The 2009, 10, and 11 should have about a 63mph top speed.
1 - 2 of 2 Posts
