I could be wrong but it looks like the headlight bezels are different too. I'd like to convert my 2010 S4 to the 2011 for some better cooling and maybe throw a few people for a curve?polaris shows the front fender section as the same as 08-11 with only the hood and front plastic nose being different.
Thanks for the info.It looks to me like you would need the steel support, the front clip, the grill, fasteners, and the hood...
some people don't like the looks of the new vented front, maybe you could trade with them?
:ride:
The 2011 has a high and low beam.I just looked at the headlight part numbers... the 2011 is new.
You might have to buy those as well.
The line drawing looks the same in both years, but the part number changed...
I wonder if that changed the lens to where the 2010 bulb base won't snap in?The 2011 has a high and low beam.I just looked at the headlight part numbers... the 2011 is new.
Man, $800? Not worth it to me... Let us know if you end up doing it to your's.I called polaris tech and they said the lights are the same and bulbs are different....cause of the high low......
I priced it all out for around $800.00 well worth the price seeing if you traded it it you'd probably be at a loss of well more than 3k...or MORE to upgrade!
I just finished the swap of the front clip on my RZR 4 (2010) I installed the 2011 Front, here are the imtems that you need in order to complete your Swap (it's a Plug & paly swap)
Part # Description
1017800-329 Support, Bumper, Front, Black
2634050-070 Asm., Bumper, Front, Black [Incl. Grill, Relector Decals]
5438411-590 Hood, Access, Center, Black Carbon Fiber
These are the only items you need in order to complete your swap, you will recycle (Headlights, bolts, nuts, Clips, Gel Decal of the Hood)
Mods that need to be done;
- You must relocate your Voltage Regulator
How much did all the OEM parts cost you OTD?
Hope this helps, will post photos this week.
Working a deal now on a 2010 and would like to do this swap. Where is the best place to order these parts?I just finished the swap of the front clip on my RZR 4 (2010) I installed the 2011 Front, here are the imtems that you need in order to complete your Swap (it's a Plug & paly swap)
Part # Description
