Hey guys my 800 fan always kicked in at 204 degrees and would drop quick back down to 188 now it kicks on at 205 but keeps climbing to 208 before dropping I have just changed water pump seal and definitely no air in the system is this normal
perfect. thanks for the info. thats exactly what i was looking for.I never worry about the engine temp as long as it's between 180-220° this is the operating range of a pressurized cooling system most thermostats do not open until 190° releasing the coolant to circulate thru the radiator
Water boils at 212° pressurized water boils at 220-230° depending on the system pressure (radiator cap psi)
One or two degrees various isn't a concern as long as the fan comes on and cools it down to thermostat dregees
