1 - 9 of 9 Posts
Ok, I ordered the UMP air filter system today, HID light conversion kit, throttle spring. What else did the 2008 models have wrong with them, other than the air filter setup? Anything else I should know about that needs upgraded? Thanks for any help.
Geezer with Joey
Those sound like a good primary step. Others may depend on how you intend to use it. You might get some other good info if you indicate what you want to do with it?
I go to the dunes a few times per year, I would like to do some trail riding, and mostly pasture riding. I just want to fix any of the problem area's on it so it will last longer. Should a guy go ahead and change the sprague in the front differential also?
Read Only
I wouldn't. If you don't engage AWD with the rears spinning, it should be alright. If it grenades, you can always change it out then.
I got the utv inc frame tubes............ When I installed them, I had one tube go in a little tight. I don't know if it was bent or just a little off. Seemed like some good insurance for relatively cheap. Safety wise, do you have a harness installed? I wouldn't rely on the factory 3 point much.
Geezer with Joey
The stock protection on the bottom and A arms is not good. and as may know the suspension gives you a marginal ride. You didn't indicate what tires were on it.
1 - 9 of 9 Posts
