1 - 20 of 44 Posts
Thought I would share my situation. It all started with a 19’ Turbo S. Imma try to catch ya’ll up quick. It gets better.
Went on 1 ride before this happened. I’m about the safety for my kids.
Things going good. Building & building away.
Discussion Starter · #2 ·
Ok. Here was the final of Version 1.
675184
675185
What she had/has now.
Sandworks Cage
Shock Therapy Spring Kit
Prp 3.5 harnesses
Assault fire extinguisher kit
Chupacabra Mirrors
KC Pro6 Gravity
RLB rear bar
Method 401-R
Tensor DSR-33’s
UTV giant doors
Force Turbos Untamed exhaust
Ok, here is where it gets good & where I found out these things aren’t very tough.
My Target:
675186
If you can’t tell, these boulders were hidden behind the brush. I was also driving into the sun. Completely came from nowhere. At least to me. 😂 45 into one of these bad boys gonna be a bad day.
675187
Trust me, it doesn’t look bad “yet”.
Got a lot more pics of the details of damage. This isn’t the end of the story tho. I’m actually far on the rebuild. Got a lot of pics & details of tearing this thing down.
I do have a day job tho. So until later….
Man that sucks. Gotta say hitting an object that weighs close to 2X what your machine weighs at 45 mph doesn’t necessarily mean your machine isn’t tough. Did you drive away from it? Hard to tell in the pic.
Discussion Starter · #6 ·
I drove it away, hard to keep straight tho. Can’t express how good a bumper is for these machines. Frame was ruined.
I was thankfully solo on this ride.
Ya 10-4. I expect most machines would be beat down after that. Sometimes it’s a roll of the dice. Although in this example physics appears to have got ya. Insurance?? You rebuilding?
Discussion Starter · #8 ·
I am rebuilding, I actually got the full front end about done on it. Just waiting on a bracket for the front diff. I got a ton of pics & details about the teardown & rebuild. I’ll be posting them later. A lot of chromoly & billet. 😎
2014 RZR XP1000
😬 45pmh I'm not surprised that it bent the frame, Glad you are ok. Your rig is looking pretty sweet though!
Discussion Starter · #10 ·
Ok. So here was the extent of the damage.
Bumper saved my radiators
Right side was caved in about an inch on the frame.
This was pretty much when I said I would throw the frame in the trash.
Discussion Starter · #11 ·
It hit it just right to make the front twist back & up.
Discussion Starter · #18 ·
That's why I welded in gussets across all the frame joints and the frame halves together on mine. They are prone to flex at the joint.
I’ve been debating on welding the bungs together to make it solid.
Just on the fence about if I want to weld new ones on if this were to occur again.
1 - 20 of 44 Posts
