1 - 10 of 10 Posts
Got a code 102 with a 4 up top and a 1 below it. What gives. Anybody else having this problem
102 - 4 (p0107) is a MAP sensor voltage below normal
Caused by the TMap sensor on the Intake plenum post TB.
can be caused by TMAP sensor, Wiring and ECU
Thanks man sorry for late reply fixing a propshaft then talking this issue
guys I'm having the same problem. I just put a new engine in my 2018 rzr 1000 highlifter. Before the engine seized up (just wouldn't start at the end of a day riding, nothing spectacular) I had that 102 engine code. it spit and sputtered a little but wouldn't shut off. once the new engine was installed the code came back after I got stuck. I replaced the pigtail to the TMAP sensor and it still acted up. I bought a new pigtail and MAP sensor and soldered the wires to the wire harness thinking maybe the butt connectors were loose...... NOT the case. still the same 102 code and still spitting and sputtering........ DOES ANYONE HAVE ANY SUGGESTIONS???????????? please help!
[QUOTE = "EballsoutS, publicación: 5969508, miembro: 275347"]
Chicos, estoy teniendo el mismo problema. Acabo de poner un nuevo motor en mi resaltador rzr 1000 2018. Antes de que el motor se detuviera (simplemente no arrancaba al final de un día, nada espectacular), tenía ese código de motor 102. escupió y escupió un poco, pero no se apagó. Una vez que se instaló el nuevo motor, el código volvió después de que me atasqué. Reemplacé la coleta por el sensor TMAP y todavía funcionaba. Compré una nueva coleta y un sensor MAP y solde los cables al arnés de cables pensando que tal vez los conectores a tope estaban flojos ... NO el caso. sigue siendo el mismo código 102 y sigue escupiendo y escupiendo ... ¿ALGUIEN TIENE ALGUNA SUGERENCIA ???????????? ¡por favor ayuda!
[/CITAR]
Solucionaste tu problema me pasa algo similar
Discussion Starter #7
Your issue is in the wires in front of clutch cover that go up to the map sensors. You have a broken wire. Try wiggling the wires around a couple times while your rzr is running it will make the code go off and on
Tengo problemas con mi polaris 550 aparece código 102 ya puse una coleta nueva, y puse otro sensor map y en este otro aparece código 105 en ocasiones batalla para prender y hace contra explosiones alguien que me ayude
Chicos, estoy teniendo el mismo problema. Acabo de poner un nuevo motor en mi resaltador rzr 1000 2018. Antes de que el motor se detuviera (simplemente no organizar al final del día, nada espectacular) tenía ese código de motor 102. escupió y escupió un poco, pero no se apagó . Una vez que se instaló el nuevo motor, el código volvió después de que me atasqué. Reemplace la coleta por el sensor TMAP y todavía funcionaba. Compuesto por una nueva colección y un sensor MAPA y solde los cables al arnés de cables pensando que tal vez los conectores a tope estaban flojos ... NO el caso. sigue siendo el mismo código 102 y sigue escupiendo y escupiendo ... ¿ALGUIEN TIENE ALGUNA SUGERENCIA ???????????? ¡Por favor ayuda!
[/ CITAR]
Chicos, estoy teniendo el mismo problema. Acabo de poner un nuevo motor en mi resaltador rzr 1000 2018. Antes de que el motor se detuviera (simplemente no arrancaba al final de un día, nada espectacular) tenía ese código de motor 102. escupió y escupió un poco, pero no se apagó. Una vez que se instaló el nuevo motor, el código volvió después de que me atasqué. Reemplacé la coleta por el sensor TMAP y todavía funcionaba. Compré una nueva coleta y un sensor MAP y solde los cables al arnés de cables pensando que tal vez los conectores a tope estaban flojos ... NO el caso. sigue siendo el mismo código 102 y sigue escupiendo y escupiendo ... ¿ALGUIEN TIENE ALGUNA SUGERENCIA ???????????? ¡por favor ayuda!
[/CITAR]
hola amigo resolviste tu problema ??? me pasa algo similar
1 - 10 of 10 Posts
