Been slow with the Xmas Holiday but small update:
After finishing the double shear tie-rod mounts on the portal bracket I started cleaning up all the hardware. I noticed the threads were slightly marred and scuff marks in the center of the ball joint pinch bolts. Hmmmmm...
Somrthing is moving that should not. Took a ball joint and slide it into the pinch block and slide a bolt in to lock it in place. With the bolt in place but not tightened I was able to slide the ball joint in/out about a ~1/2" and this is slop than I'd like. I had new portal brackets on the shelf so I tried it with a new bracket and the in/out play is only ~1/4". So the brackets are worn some, interesting as I always check everything over that there was ZERO movement in the ball joints. I use a paint pen on the bolts so I know they had not loosened and I use ARP bolts torqued to 70ft/lbs so I know the bolts did not stretch.
This was after a complete season of riding but more wear than I expected so I started looking for the source of the wear. Studying the pinch I noticed an odd wear pattern on the outside flange where the bolt/nut rest. There is a small rib (I assume from the forging process) that was never machined flat. You can see where the bolt head was only touching the pinch block in two small spots (same on both side). This is a problem! This will not provide a sufficient surface for the correct clamping force needed to keep the ball joint from moving. It will also skew the torque settings. How I did not catch this when I originally installed them I have no idea
So next the fix:
I tossed the old bracket to the spare parts pile and started with new brackets. I machined a flat surface on both side of each pinch block. This should have been done from the manufacturer
@SuperATV
I think I'll have a talk to them about it. One final machine process would not add that much cost to the product but it would improve it 100%.
I forgot to take a picture until after I painted them.
Here are two pictures comparing two brackets, one machined and one the way it came. You can see thow the bolt head does not sit flush.
From the factory:
New bracket with the pinch bolt machined flat and the bolt head sits flush.
If you have portals I would suggest fixing this issue. If you don't have access to a mill you can do it with a grinder or a file.
I have seen a few lower pinch blocks broken off. This is a out of thousands but still a few broke. The top pinch block is welded to the backing plate and upper lip proving good support. The bottom pinch block is just welded to the backing plate with no support. This relies on good penetration during welding to keep it secure and this has been the source of teh few failures I've seen. I inspected both new brackets and the welds look good but I wanted more support. I made a couple of support pieces from .250" bar stock and welded them to each side of an old bracket. I wasn't real happy with the look, just not a "clean" look to it. After contemplating for a few I came up with the idea of welding them from the back side of the mounting plate. I drilled two .500" holes through the back plate and penetrate the pinch block ~.250". Then proceeded to weld the holes up and you's never know it was done and adds considerable strength. I would like to see SATV made the bracket with slots behind the pinch blocks and weld them from both sides. Another idea I'll suggest to them.
Couple shots of the double shear tie-rods setup made from .250" flat stock. That's a 3/4" FK heim with a 5/8" bolt to go along with the hydraulic ram 😀
Yes I know the wrinkle paint I used does not quite match. I'll have them powder coated later 😝
I'll make a seperate new thread about the brackets as I think this is something everyone should do that is running portals and large tires.
Ok time for a
and then back to work.....
