1 - 10 of 10 Posts
Thinking about putting 15x7 Method wheels on all four corners of my 2020 1000 XP. Does anyone know which offset (4+3 or 5+2) will give the closest to stock overall width of 64 inches? Trying to keep as close to stock width as possible due to trails I ride having width restrictions.
Thanks in advance.....
2020 Polaris RZR 1000 XP Premium
2008 Polaris RZR 800
I have roughly the same question I have tried to figure out what offset I need to run the same size tires all around and stay at 64", I tried to figure it out but since 2+2=MATH for me it just ends up hurting my brain. Or maybe im just lazy and want someone else who has done it to tell me the offset I need.
If you can find the wheels you want in a 6+1, that will keep you as close to stock as possible. If not then go with the 5+2, the 4+3 will really make you wider with lots of scrub issues and bump steer
Sti, method, race line, tusk all have 6+1 beadlock. Just have to search
sti HD9, Tusk Teton, system 3 SB-4 are just a couple of examples of beadlock wheels with 6+1 offset options
Stock Polaris 6":5.4+0.6, 137+15(+62mm)
WalkerEvans 6": 5.125+0.875(+54mm)
This wheel is the closest you are gonna get to stock offset (8mm).
Some 5+2 's are as much as a 32mm difference.
Yes 6 +1 offset wheels will get you closer to stock but you have to look at the "fine print " on the manufactures measurements as a lot of time the term 6+1 is a marketing term. Some manufactures are closer than others.
I have 5+1 Raceline podium headlock wheels and I love them I would definitely stick with a 5+1 or a 5+2 or 6+1 to stay as close to stock you don’t want to run into bump steer issues with the 4+3 “Dish” wheels
655768
Maybe this might help someone in the future when they visit this post. this was taken from Method Wheels website.
655784
1 - 10 of 10 Posts
