1 - 13 of 13 Posts
SOLD !!!!!130hp one of A kind RZR … cheap. Honda RC51 1000cc powered with reverse !!!
My garage is full of RZRs and wife wants it gone now. $12,500 or best offer takes it with no wheels/tires. Well over $30k invested and very reliable ride. Has RPM gearbox with reverse!!! Tons of upgrades. Someone needs to take this off my hands as much lower will be parted out soon which would be a shame.
Engine:
The RC51 engine has a cult following. Was the top superbike/track bike and known for its reliability and high torque v-twin. Modern engine with fuel injection, DOHC, 6-speed, liquid cooled, etc., etc.
Comes out of a Honda RVT1000 RC51 and is the newer SP2 engine with some known simple tweaks for power
Custom aluminum oil pan for off-road ground clearance
Stock air box with K&N filter/foam pre-filter
CBR600 ignition coil upgrade
Engine is mounted more towards front and centered … much better handling.
Dual exhaust with custom headers that are wrapped, GYTR polished cans
Power Commander III USB with full dyno tune and custom map
Uses stock RZR fuel tank/pump (a high flow pump upgrade was done)
Remote oil cooler located upfront for airflow
Drive:
Stock 6spd RC51
Wilwood clutch with pedal. Custom fabrication to make spot for clutch pedal in line with brake/gas pedals just like a car.
2WD- stub axles on front
RPM forward/reverse gearbox with adjustment linkage and proper stops to keep chain from loosening. Remote overflow/breather. Has a 1:1 ratio. Geared for duning, you will use all six gears. Gearing can be changed within RPM box if you want highest tops speeds or more use of all gears.
EK 520 ZZZ zero stretch chain drive. I have had no chain issues with this setup.
Custom chain guard to keep oil from slinging
VW CVs
Custom Sway A Way axles
Barnett clutch clutch kit just installed. Only gone through one clutch in 2.5 years and its easier/quicker to change than a CVT belt for sure
Billet shifter
Suspension:
UTV Inc./XMF +6in long travel
Walker Evans remote reservoir shocks
Rear shock tower braces
ATI rear sway bar
MakinTrax Progressive springs front and rear
Cage:
One of a kind custom by JaggedX. Full wrap around to rear with integrated rear bumper. Integrated light bar and roll over protection.
Dragon fire rear opening doors
Chassis:
Not stretched !!!
Lonestar welded in gusset kit front and rear
UTV Inc. tube inserts welded in
Lighting:
Four TrailTech HID’s on light bar. Upgraded balasts on all.
Stock headlight HID conversions
Interior billet LED light mounted to cage
Gas cap LEDs
Properly wired with relays where necessary
Steering:
Rackzilla box and tie rods
Grant steering wheel, billet mount, billet steering cover
Dash:
Custom panel to integrate stock RC51 digital gauge cluster. Only function that is not avaialble is fuel level.
Speedometer correction via GiPro SpeedHeeler
GiPro gear indicator
Sealed switches
Seats:
Twisted Stitch seats
DJ Safety five point belts
Wheels, etc:
Wheels/tires not included ...
UTV Inc. billet hubs
Misc:
Storage bag on rear of cage
Polaris “glove box” bag on OS bar
Billet OS bar
Whip mount wired for lighting
Large trophy truck billet side mirrors
Axia Alloys panoramic rearview mirror
Odysset 925 battery in custom aluminum box
Fuel Pressure gauge
Tons of power and torque is unreal. Really puts you back in the seat. Best thing about this one is its ready to go ... everything done properly and functions great with no reliability concerns ... it's a HONDA !!! Nothing like getting full control back with a shift lever and being able to rev the engine when you want. Gets lots of attention ...
Re: 130hp one of A kind RZR … cheap. Honda RC51 1000cc powered with reverse !!!
$11,500
Wow smoking deal. Looks like fun to drive. good luck selling it.
◄►STARS & STRIPES◄►
Heii Yeah it is, what a heart breaker... To put that much work in & let her go.... Someone is going to be HAPPY!
Good Luck on the sale! I'm sure you'll have some bites by days end :)
Wazz
RZR Junky.....
That is one awesome machine, wish I lived closer to the dunes. Glws.
Drew
that is a fine piece of work, surprised it hasn't sold already
Very cool rzr....awesome price too....
Discussion Starter #13
SOLD !!!
Thanks everyone ... it is a fun ride and buyer got a crazy deal ... was a bit of a heart breaker for me.
1 - 13 of 13 Posts
