The wet sump on the 2014 frees up some space in the bed and allows for a flat bed floor too.
Downside is that you have to remove the seats again to check the oil.
As long as the oil is fresh and clean, I don't really see it being an issue. If you're worried, maybe change the oil more often and make sure to use a good synthetic. I think either one will be fine.
