1 - 20 of 24 Posts
Well ive been lucking and finally decided to post up. Well i had 30 hrs on my RZR and went out for a day of highspeed fun just flat out fields. Well i did my preride inspection set tire pressure, check oil coolant all the norm stuff. Well about 2hrs into our ride my rear tires locked up and unlocked and stalled the engine.... tried to start it again and it was knocking.... rod knock...
I was livid 30hrs on my machine and i spun a rod!!! so i got towed home to the trailer and went home. Called the dealer and they said theirs no way.... so i bit the bullet and dove head first into it....
What i found i was right i spun my Mag side rod... So bout 2000 later i got her all back together and rippin around... i still don know how 2.5qts of oil went missing... i checked high n low when i rebuilt it no avail...
Just wanted to share my story thanks for reading.. if anyone finds my oil let me know lol:ride:
I am very picky about stuff the dealer said they would look at it but word about their shop is not very highly spoke of. So I decided just to do it on my own Ive built a few motors for cars so i figued this should be not too bad and it wasnt with a manual in had and step by step it was easy.
My 2011 kept having a wet pan and never could find the leak. Most of it happened while it sat in the garage. I'd come back from a ride and it would be dusty, not wet. Go out into the garage a week later... wet pan. A year later finally took off the skid plate and 3 of the oilpan bolts on the front side were less than finger tight.
Same thing happened to my 2012 rzr 900 xp, engine started knocking bad and spun the lower conecting rod bearing, oil disappeared, only have 6500 km on it,so it's still at the dealer waiting to Ben fixed.
same thing happened to my 2013 jagged x......only 1200 miles on it....after a fresh oil change......where does the oil go? Good thing....polaris covered mine under warranty....bad part...my rzr has been in the shop since sept 21st...waiting on backordered parts:rm_thumbdown:
GAcaley, yu said yu used a manual in hand, i just lost my 2012 rzr xp900 today and i am a backyard mechanic also witha few engine reuilds over time, where did yu get the manual?
bomark2002, we can completely remanufacture your 900 RZR engine here at nFLOW for $3,385 with core exchange with Free Shipping both ways in the lower 48 states. Our reman process includes a complete tear down of the engine, washing and media blasting, replacement of worn and damaged components, in house CNC machine work, reassembly by our skilled techs, final inspection/testing, and shipping back to your doorstep. Our engines come backed with a 90 day limited warranty and financing is available. The engine will come back looking and running like new in 14 days. All you have to do is strap the engine to a pallet or place it in a plastic tote and we take care of the rest including arranging all shipping logistics. Give us a call at 812-402-8282 and ask for C.W. Thanks. www.nflowmotorsports.com
Going to need full gasget kit for top and bottom, and a ring kit. Sand destroyed old ones but rest checks out on spec. Bummer for only 118 hrs
1 - 20 of 24 Posts
