10 hour fluid change
1.2K views 1 reply 2 participants last post by  Timmi
I have reached 10 hours on my 2014 570 le. I decided to change all the fluids and wanted to let all of the new rzr 570 owners know what I found. I changed the oil and filter and glad that I did, the oil was dirty. I know they suggest changing the oil after 25 hours but happy that I changed it at 10 hrs.
I changed the transmission and front drive both oils looked ok with the front a little dirtier then the trans.
I checked the spark plug it was a champion plug and had a lot of carbon build up so I changed it to ngk cr9eix iridium.
checked the air box and all looked good, glad I put grease around the lid because I could see where dirt was trying to get by and would of if I hadn't put the grease around it.
I hopes this info will help.....
