1 - 20 of 23 Posts
Contact: 855-743-3427
Get more ground clearance when you install a RZR adjustable lift kit made by Super ATV. Lift Kit is Zinc Plated for long lasting durability and a great look. Perfect for adding additional ground clearance. The shocks are strategically place to allow a lower Spring Rate which inturn is not pinching the shock which requires it to use twice the pressure to keep the RZR Lifted. The will also help your CV's and CV joints to last longer as well.
This week for $135.00.
ATV ACCESSORIES - RZR LIFT
Tyler
SuperATV.com
(812)574-7777
I know alot of kits claim to be a 3" when really you only end up close to 2"... How much lift does your kit actually provide? I'm still trying to figure out which kit I wanna go with
Discussion Starter · #8 ·
You are correct in that statement, our kit is 2.75" in the front and 2.5" in the rear we discovered anything more then that with stock axles will break them especially in the rear. If you have anymore questions feel free to ask or give me a call at (812)574-7777.
Thanks,
Tyler
I'd like to get someone that has this kit also to see how it works,getting a new 2010 le sat.and dont wanna get a kit thats gonna wear it out quick.I read with the lift kits that it binds the wheels turning or something?
jsw did you get it and install?
Wow looks great. Did u do the adj.?and if yes did u set it to the 3" no bind?
I didn't hear any binding, but in reality I think it would be hard to tell what kind of stress is really going on in the axles... Took it out for the first time on Saturday and with the lift and new tires it made a world of difference. I'm happy with the kit, but think superATV might wanna look into a design change for the rear part of the lift and re write the directions for they really aren't written great.
Discussion Starter · #17 ·
Thanks for your input, i will have the rear brackets looked at the the directions revised this week.
1 - 20 of 23 Posts
