how much compression should a bone stock plain jane rzr have with 224 miles and 27 hours have,i bought it used and air cleaner had a palmful of dust in it,does have the supposedly fixed air cleaner on it,previous owner never cleanded it,seems to run good, i have been reading your horror stories on dust,what is lowest compression can be to not have bad top end or dust damage,and what should it be on average no dust damage,should you let it crank all the compression you can get in gauge to check it,and should you put a couple of drops of oil in spark plug hole for good reading because of all the fuel you pump into cylinder and partially unseal it while doing first cylinder cranking alot repeatedly checking it?
