So I accidentally took my TPS sensor out the other day then realized that was a bad idea :rofl3: so I had to back pedal and learn how to adjust it correctly. I've researched all the threads on here and got it adjusted to what i think is right (.735). i got it to .735 with the key on and engine off. but when i turn the engine on it goes up to around .745. Does it matter if it goes up with the engine on? Do i need to set the TPS with engine on or off? Also what should the idle be set at? Thanks for the help!
