08 800 50"
was going to put rear wheel spacers on tonight
after jacking the rear end up noticed the right rear wheel was sloppy
pulled wheel, brake caliper off removed castle nut and pulled hub
the portion that goes into the bearing was snapped clean off the rest of the hub
obviously need to replace this and will put new bearings in
anyone have an idea what would cause this kind of failure
left side is still intact should i replace this one while its down cant see any cracks.
any other suggestions for things to check while I have it torn down
have a big ride coming up in two weeks and dont want any more issues
cheers
int:
cheers
