The Agency Power Silicone Intake J-Tube for the Polaris RZR XP Turbo is a great upgrade to help improve air flow from the intake to the turbocharger. This new silicone tube replaces the factory plastic intake tube. The silicone tube has been designed not only to enhance the performance of your RZR Turbo but also a easy installation between the turbo and airbox. Each tube is constructed using 3 ply silicone material with a smooth inside that helps eliminate any turbulence caused by corrugated designs. The silicone intake tube is much stronger and durable than the factory tube allowing it to hold up much better to the harsh elements. As a simple add-on upgrade, there is no modifications that need to be done for installation. Each silicone charge tube includes a MAP sensor port, crankcase breather port, and blow off valve port to work with factory components. The Agency Power silicone J-Tube is available in black and features the AP logo.
Features:
3 Ply Silicone Construction
Stealth Black Look
Simple Bolt On
Fitment:
2016-2018 Polaris RZR XP Turbo
2016-2018 Polaris RZR XP4 Turbo
2018 Polaris RZR Turbo S
The Agency Power Silicone Turbo Inlet Charge Tube is a great upgrade for your Polaris RZR Turbo. The new silicone tube replaces the factory plastic unit that connects to the compressor side of your turbocharger and throttlebody. The new 3 ply silicone construction is very durable with a smooth design that helps eliminate any turbulence caused by the factory corrugated tube. This enchanced silicone charge tube provides much needed airflow efficiency. Designed as a simple add-on upgrade that all Polaris RZR Turbo owners will be glad they did. Agency Power includes an extra vacuum port on the charge tube for those looking to add an aftermarket boost gauge or need to the vacuum source. Each silicone charge tube includes all clamps and hardware needed for installation. A CNC machined aluminum MAP sensor port and blow off valve port are included to work with factory components. Hoses are available in black and feature the AP logo.
Features:
Stealth Black Look
Simple Bolt On
Additional Vacuum Port
Fitment:
Note:
View Install Instructions Here
All Agency Power parts come with a limited lifetime warranty when you fill out the form here.
