aux fuel tank idea - Page 2 - Polaris RZR Forum - RZR Forums.net
 3Likes
post #16 of 23 Old April 16th, 2019, 06:56 AM
Elvisff's Avatar
My RZR: XP4 1000
Member #71985
View Elvisff's Photo Gallery(0)
Re: aux fuel tank idea
Originally Posted by lifebeginsafterdeath View Post
SNWMBL, i'll have to read it, how is it listed? I'm not sure if the coins are worth it? Still wondering how the https://www.isotallc.com/rotopax-kit-or-bracket.html would do and it over 50% less the cost and seems to be a lot easier to install.
Not sure where you get less than 50% of the cost. The isota kit with rotopax is $350. The standard IMS tank is $399. The rotopax are definitely to easier install.
Elvisff is offline
post #17 of 23 Old April 16th, 2019, 07:00 AM
lifebeginsafterdeath's Avatar
My RZR: 2017 RZR 1000 XP, Shock Therapy, SwayLoc, Mud Busters, BCC full skids
Member #60379
View lifebeginsafterdeath's Photo Gallery(0)
Not looking at getting the standard, looking at premium with battery or possibly not getting battery
lifebeginsafterdeath is offline
post #18 of 23 Old April 16th, 2019, 08:13 AM
SNWMBL's Avatar
First Name: Caleb
Member #207521
I bought the IMS kit that relocates the factory battery and the bracket they send is very nice. Heavy duty, well built and powder coated.
I chose the IMS over the ISOTA setup for a couple reasons.
1. Weight is lower in the machine
2. Automatically transfers fuel while you ride and it works great. Iíve ridden with the low fuel light flashing before I filled it up and there was only 1/2 gallon left in the tanks.
3. Gives me more room for storage, we carry a lot of stuff and the ISOTA tanks eat up valuable real estate.
4. Filling at the gas station is super easy. I donít fuel thru the oem tank only as itís faster to fill both the IMS and oem at the same time.
Itís a great setup and I have no regrets.
2017 RZR XP4 1000
Alaska UTV Fab LLC
Instagram: alaska_utv_fab
FOR SALE
- Hunterworks secondary rollers, set of 2, $35 shipped
- Sinister Fabrication A pillar bungs, set of 2, $45 shipped
SNWMBL is offline
post #19 of 23 Old April 16th, 2019, 09:02 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
There's this for the XP1000: https://utvactionmag.com/ims-rzr-xp1...lon-fuel-tank/
Denver is offline
post #20 of 23 Old April 16th, 2019, 09:07 AM
Denver's Avatar
First Name: Denver
Member #41951
And this for the XP900: https://www.rzrforums.net/ims-produc...rzr-900-a.html
Denver is offline
post #21 of 23 Old April 16th, 2019, 11:04 AM
Member #60379
Yea, i came across that and read it and forwarded it to IMS because it states near the end on the line marked "verdict" that they were only able to get 4 out of 5 gals but Daniel with IMS has no clue or why they'd state that.
post #22 of 23 Old April 16th, 2019, 11:08 AM
Member #60379
how do you fuel thru the IMS? I tried to get IMS to send video but it was too big to send. He sent instructions. tks
post #23 of 23 Old April 16th, 2019, 11:21 AM
SNWMBL's Avatar
First Name: Caleb
Member #207521
The factory tank holds 9.5 gallons and the IMS holds 5 gallons. When I filled both takes after install I put in 14.5 gallons so the tank capacities are correct. I have put as much as 14 gallons in to refuel. Based on my personal experience, all but the last 1/2 gallon is useable, maybe less. I had been running with the fuel light flashing for quite a few miles because I wanted to test the useable fuel capacity. I did not run dry so itís possible there was even more fuel available. Iím happy with 14 useable gallons of fuel. Thatís about 130 mile range for the riding we do.
The IMS tank has a threaded bung installed in the bottom and you have to install a fitting into the bottom of the factory tank, then a hose connects the two tanks together. The fuel just transfers over as you ride.
2017 RZR XP4 1000
Alaska UTV Fab LLC
FOR SALE
SNWMBL is offline
picked up a TH... anyone good with Onan's allcool Tow Rigs, Trailers and Camping 59 July 18th, 2017 11:41 AM
2015 900 Trail and 900 XP Fuel tank Pressure RZR Wii General RZR Discussion 6 April 14th, 2017 07:21 PM
Fuel tank swap Ridgeman RZR 800 Specific Discussion 16 July 5th, 2015 06:13 PM
The 411 on Fuel Controllers, please read!! Hunterworks Hunterworks 45 May 12th, 2014 06:32 AM
